I\'ve been using GW sable brushes, and whatever else I could find, for some time now as they\'ve been the cheapest and most easily accessible.
However, like most of the brushes I\'ve found, they don\'t seem to work too well with GW paints.
GW paints dry awfully fast. Making assembly line work, drybrushing or even large painting projects and real chore for the brushes.
Invariably, GW paint will dry up on the bristles. Despite your best efforts at a clean brush, it never fails that you didn\'t quite get it all out. The next time you use it, you end up breaking the paint and the bristles fan out, making the brush useless (this is especially the case with brushes used for \"drybrushing\").
With some paints in GW\'s line, you have to clean the brush with every use (because the paint\'s naturally tacky), which increases wear and tear.
Obvious answer is \"don\'t use GW paints\". However, it\'s not always the case. With all acrylics I\'ve used, if I\'ve painted for any length of time, the paint seems to dry on the brush.
So, are there any ways to prevent this fragging?
Are there ways to remove the dried paint from the bristles without ruining the brush?
What brands of brushes do you find more durable and can hold their shape better through long periods of wear and tear?
