Flightless
I want to base everything in my army.
Everything!
This means i\'m looking to base tanks...
Somehow i would like to construct a couple of bases to match the standard GW round ones (~4mm thick), but about 100mm across.
It will be removeable, almost definitely using magnets (basically unless that isn\'t possible given the base).
The only thing i have been able to think of so far is using milliput, rolled out, cut a la cookie cutters, and then laboriously sanded around the edges. But i\'m worried that will end up with a horribly heavy base, or be otherwise unfeasible.
Plastic that thick would be stupidly hard to cut, let alone to refine. Or even buy, come to that.
Your suggestions will be appreciated.
Everything!
