Landing Craft Model/3D Printable Model
comedianmasta
Hey guys. My friend just bought a 3D printer and was looking for rivet wars stuff to print. I thought the PERFECT thing would be one of the landing crafts! I wasn't sure if anyone had made a printable model of the Landing craft or anything close that we might be able to use?
If not, anyone have any ideas on what to use for the landing craft?
Lance King
I am going to write this up as a separate post but if you can get one of anything you can do a 3D scan of it for printing. If you have a high end printer it may have a scanner built in. If not local public libraries are starting to support both 3D scanning and printing. There are two nearby libraries that are in to 3D: one scanning, the other printing. You usually have to do some sort of sign up and maybe an orientation class but after that you can access the services.
Scarbuck
Those are pretty cool, but will require some modification for your purposes. Mostly in the scaling, but you'll want to figure out where you want to put your plugs, and even if you don't create a hole for them (and use a drill later), you'll want to make sure there's space for it.
comedianmasta
I saw those, I was afraid they were too small. That's why I liked the ones Ted posted, that were somehow the right size. I see a little space, can you fit tanks or something in there? Or is that it?
Lance King
Single width stands only. But there were different types of landing craft. So a different one for tanks or double-wides. If you get a craft that is too big then unloading quickly might be an issue. If you are under fire you want rapid deployment. With a little fixing up and reducing the hole size for a MG plug, I think these are perfect for smaller units. I'll post follow-ups later on.
