It gets worse before it gets better
Target
<p>After successfully sacrificing itself to save the remaining empire army when the shelf fell in my cabinet, I thought I owed it to its crew to attempt to put it back to gether again.</p><p>Therefore most of yesrday was spent taking apart and reassembling this huge hunk of metal. I had originally assembled it without the turret and with a hellblaster cannon as its main cannon, because I could in the old version of the rules and because it was funny to have a steam tank running around with a killing machine attached.</p><p>Unfortunetly this combination is no longer allowed to it was straight to my bits box to see what I stil had. I have found the turret and captain, but had to nick a great cannon from a old kit.</p><p>The back axle on this monster is designed in such a way that once it has collapsed it is almost impossible to get back together. Three hours I spent putting this together and eventually decided to pin every joint, but not before I was covered in super-glue.</p><p>Is this the most fagile model there is (not withstanding Rackham of course)?</p>
Jericho
Consummate Brushlicker
I recommend you look up the Gnoblar Scraplauncher. It's probably the most fragile/prone to breaking model I've ever seen. When I worked at GW for 2 years we had one in the store army, it got broken almost every single time someone used it. Big heavy model with tons of thin, awkward parts stuck to the top. Good idea GW :Þ
