Improving my airbrush technique
gilljoy
Hey all,
I'm looking to improve my painting technique and I'm having some issues with my airbrush.
I've got one main problem. I tried doing a zenethal technique and the finish seems very very matte and almost powerdy. Anyone have any tips on how to avoid this? I went from sombre grey to wolf grey if that helps clarify what I'm talking about. Its quite hard to get a good photo of the problem tonight.
MAXXxxx
move in more steps, like when painting.
in the 2nd tip I'm not 100% sure, but if you use more air, the paint-drops become smaller, so less powdery/chalky effekt.
me_in_japan
What are you thinning it with? I found I had this problem if I used too much water. Airbrush thinner (I used Tamiya stuff) seemed far less powdery. That might be your problem?
gilljoy
Cheers for the rellies guys. Currently using vallejo paint and vallejo thinner.
Its really annoying going to have another go tomorrow and see if i can get them less chalky
Off the bat, I'd say you're too far away. You're dusting the mini by shooting from too far away a.d the paint is drying on its way to the mini.
t77mackie
A great resource for airbrush techniques that you can apply to miniature painting is plastic model sites and magazines. Check out Hyperscale.com and Fine Scale Modeler magazine. I do WW2 model airplanes and miniature painting and techniques from both schools can garner great results.
One thing I can say is I only use plastic model paints in my airbrush and I use Reaper / Citadel paints when brushing. That can be expensive though when starting from scratch with a new line of paints.
If you're getting a 'powdery' finish it sounds like you're either spraying too far away, using too much air pressure, or a bad thinning job. Acrylic paints are meant to be translucent so you will get best results with several light passes. Thin your paint way down to the consistency of milk, then slowly raise your air pressure from zero PSI until you get a consistent spray of paint. You're going to want to be painting from about 1-3 inches away from your piece. Practice, experiment, repeat. To get some really spectacular blending coats try using Tamiya acrylic paint thinned with their own or Mr. Color brand Lacquer thinner. You'll get some really nice, smooth, translucent blends perfect for the technique you're looking to do.
I haven't been able to get good results using Citadel or other miniature paints through my airbrush but I haven't really tried all that much. A drop of Liquitex flow-aid to an A/B mixing cup of acrylic paint may help things a bit. Always use your paint's recommended thinner.
I'm assuming you're painting vehicles of some sort? Try using Tamiya, Mr. Color (Gunze), or Testors Model Master / Poly Scale paints if so. Again, use the recommended thinner - people say that Tamiya thinner is just isopropyl alcohol but it's not; it has some special Tamiya fairy dust in it that works wonders.
Happy painting!
gilljoy
Happy painting!
Thank you for the advice :)
I think I'll maybe pick up some tamyia paint for painting tanks etc. I've been using citadel paint and vallejo paint and thinning it with vallejo thinner. It seems to be working quite well so far. I sprayed a load of space wolves minis last night and they were a little dusty until I gave them a watered down wash / filter which blended things together a lot
No need! Plenty of the best armour modellers use Vallejo paints so you can be assured they're more than good enough for the job.
Given you're still reporting problems with a slight dusty finish, I just wanted to check, are you trying spraying from closer to the model? If you're not because the surface keeps being flooded just drop the amount of paint being sprayed - with any airbrushing you're seeking to balance air flow and paint flow, depending on all the variables in your situation (paint type, nozzle, pressure, distance, RH, airbrushing juju).
Another thing that might be an issue that nobody else has brought up is spraying a too-light colour over something darker; no matter whether the surface is truly dusty or not it'll look dusty (hence this is exactly the technique you use for achieving dust effects) so try to bear the transition of colours in mind. Even though airbrushes are very good at making smooth graduations from any colour to the next, when you're spraying opaque paints you'll tend to get noticeable problems with a dusty-looking result if the colour is too different from the one you're spraying it onto.
