Anarchy Models
Hey guys!.
Some of you lovely people here at cool mini backed one or both of our previous stencil projects, So I thought I would drop in and tell you about our latest kickstarter Campaign we are running during October 2015.
Our new Kickstarter is now LIVE! ....click here to view it.; https://www.kickstarter.com/projects/805848592/hs-stencil-system-wave-2-from-anarchy-models
HS Stencil system.
HS stencils are;
Sorry for the size of the images, i tried deleting them, but they are still here.
click here for more info.; https://www.kickstarter.com/projects/805848592/hs-stencil-system-wave-2-from-anarchy-models
Thanks!
Hey guys!.
HS Stencil system.
HS stencils are;
- Fully re-usable - With proper care, HS Stencils will last for years.
- Semi-transparent - You can see where you are putting the stencil.
- Washable and solvent proof- Simply clean with a suitable substance for the paint you are using.
- Thin and Flexible- Will produce a softer edge - In some cases you may not want a really crisp edge like our HD stencils provide.
- Not Sticky - HS are used either freehand or by taping to the model/item
- Quick to use - you do not have to spend time making sure the stencil is stuck to the item, and in some cases you may not need to mask off the rest of the item.
- Easy to use - create amazing paintwork, quickly, with even a basic level of skill
- Best used with an airbrush
Thanks!
