Help me make a tank! (with magnets!)
Flightless
OK, i\'m making a tank.
Very much along the lines of Athamas\' from Warseer:
http://www.warseer.com/forums/showthread.php?t=9042&highlight=magnets
I\'ve ended up with a lot of questions. But i think i\'ll bring them to you one at a time.
My first one will simply be:
How would you suggest i get rid of the joins between the side and top armour? You can see it clearly on Athamas\'.
I\'m realising tanks are incredibly annoying to do - so very many faults to correct, and irritating places that the mould lines need to be removed from (we\'ll see how far i get with some of them...).
Oh, ok, i guess another question wouldn\'t be amiss:
What size magnets should i go with? I think the smallest i\'ve found so far are 1.5 x 0.75 mm, though i\'d go larger than that if that\'s better. But i can\'t interpret the Gauss measurements or whatever, so i wouldn\'t mind knowing what sort of hold i can get.
Ideally i want magnets that will prevent the things attached to them swivelling, since i intend to use them to hold the weapon on the predator turret (one on each side of the mounting, so 4 overall) if i can.
And since we\'re talking ideal, i guess knowing whether the same size would also be appropriate for fake piercings... (got some people to worry)
If nothing else, someone mentioned an article about using them, but i can\'t find it and the search doesn\'t appear to work.
Right, more questions will follow. This is going to be a long process... Thanks.
Recoil889
Here you go. Im in the process of making a pred with this tutorial. Hope this helps
http://www.hobbyhawk.com/Tutorials/TheGreatBeaver/BeavMagneticPred.html
I would use an epoxy putty to fill those gaps like green stuff or miliput. Or you can get thin styrene strip, find one the right thickness and fillit with that.
Flightless
Nice article Recoil.
Whilst obviously i want it held securely enough not to flop down, can the turret armament be angled up and down on purpose?
Also, where did you get that hatch and mounting on the turret? I don\'t have anything like it, and yet it doesn\'t look like you\'ve done any conversion to it.
