Help linking
barkel
In a topic under the wish list category WightZombie mentioned that you could link two of your posts together. For example, I have a post of the front of my dwarf warrior and a separate post of his back. I tried add a link that will take you from the post of his back to the post of his front, but all attempts have failed.
http://www.coolminiornot.com/index.php?id=32784&c=All&m=All&nm=none
This is a link to the post of my dwarf back. You can see where I tried to link it to the dwarf front, but failed. Can someone please explain what I am doing wrong.
barkel
wightzombie
hmmm try this, like the forum code
add the words
[ url=
in front of the link below to get it to work
http://www.coolminiornot.com/index.php?id=32784&c=All&m=All&nm=none]Click here for 2nd view of my model
then add this at the end [/url ]
if you have another model save this txt and just paste the link in over the old one.
i had to put spaces between the [ ] so they would show upin the forums so remove the spaces from the brackets so remove the space before [ url and remove the space url ] at the end.
hope this works/
