miwashi said:
I've never used Green stuff before but I use Tamiya epoxy (the quick type) and I found it very sticky.
Have you tried playing with the proportions to see if you can reduce this? Most epoxy compounds are a little forgiving when it comes to varying the amounts of A and B (some are
very forgiving) and if you use more hardener than resin the putty will tend to become less sticky as well as smoother and/or a little stiffer.
Either instead of this or in addition definitely test out some alternatives to water to lubricate your tools - saliva, moisturiser, conditioner, dishwashing liquid and of course talc are all worth experimenting with and IMO all of them are better than water. I'm not in favour of using oily lubricants for sculpting generally but vegetable oil or petroleum jelly are worth a shot too.
If you want to try something else that's very much not of the too-sticky type then I'd highly recommend MagicSculp, and it's relatively inexpensive too (large pack sizes available).
