I saw some miniatures made by Stefan of Masquerade miniatures done in Tamiya putty. It works well for him. I got a packet from him but have yet to try.
As to Fimo colours, it does actually matter what colour you choose. Some differ a fair bit in properties from eachother. Here is a bit from the 1listsculpting FAQ.
(I included a bit on how it is sometimes used in combination with epoxy putties)
Polymer clays and epoxy putties can be used together. They can each be used for the part of the sculpt they are most suited for, but can also be mixed to get different properties. Some masters, like several by Rackham, are made primarily using Polymer clays --on which, details are added in epoxy putties. A common combination is:
- Fimo Soft or a mix made of FIMO Classic and FIMO Soft. Not all colors have the same properties and a favorite color is Champagne. Other colors mentioned are Flesh, Light Grey, and Green. The FIMO is used for general sculpting.
- Kneadatite blue-yellow to add fine details (it\'s a lot stickier).
- Milliput/ A& B or another hard putty for making mechanical parts (like weapons).
When using a combination like this, one does have to take care when baking the sculpt (like polymer clay). Cyril mentioned on another list that Andrea Sculpt and Milliput can take 150 degrees Centigrade OK with some browning, but that Kneadatite blue-yellow can let go at those temperatures. Longer baking at a lower temperature (not more than 120 degrees centigrade) is recommended. Do note that normal baking temperature is 130 degrees centigrade.
Bye, Ming-Hua
