I've been playing around with the trick of putting on a layer of gloss varnish before a wash, and then using alcohol and foam brushes to clean up the wash so flat surfaces don't look dirty. This works great but the alcohol also eats the varnish I use so I have to be very careful not to penetrate through and damage paint I want left alone.
Are there any varnishes I can put over acrylics and that acrylics will stick to that resist alcohol? Will oil-based varnishes work? I've read oil-based varnish yellows with age, is that the case?
