Foliage?
Sauce Devil
Where to get it from - preferably cheaply?
I was looking at this mini and if it\'s in 28mm scale the foliage is very tiny and delicate:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=150273119611#ebayphotohosting
What do you use?
Bastetcat
much of that base foliage looks homemade to me. Folks will sculpt with gs, use dried herbs or moss, cut out plastic card etc. Look around your house and you\'ll probably find some. OK, if your house is like mine you will. :rolleyes: I just saw some confetti that could be bent and painted to make cool leaves and plants.
I said \"bent and painted\". *snicker*
Sauce Devil
Thanks Bastecat.
I sometimes use cut-offs from plastic flowers but although they look okay for tabletop minis they can\'t be painted.
Are dried flowers too fragile? Whenever I\'ve picked up dried flowers I found that they crumble very easily.
Wren
Looking at the front view, the pinky-purple fronds are brass etched foliage. I\'ve used similar ones, which I got from Hasslefree as Thunderhawker mentioned. I think all the vines and tiny green leaves on the base have been sculpted to match the vines and leaves sculpted on the figure. There might be some sprigs of dried moss on there too, can\'t quite tell.
The purple flowers just below the feet of the mini look like some I have marked \'candy tuft\'. Varieties called gyp, mini gyp and caspia are also suitably sized for use on minis. You might bring a mini with you when you shop for dried flowers, it\'s easy to think something is small enough out of context when often it will be too large. The dried flowers on this look to be either naturally coloured or coloured by the manufacturer, but it is possible to paint dried flowers or enhance them with paint.
Dried flowers can be on the fragile side. Generally you can work with individual blossoms, so even if they fall apart to the touch you can glue on the parts that fell off. Some should be sturdy enough to handle as sprigs. But overall I would reserve use of dried flowers for display pieces more than game pieces that will get handled a lot. Brass etched stuff is sturdier, but you still want to try to avoid having it near the edge of the base or other parts that will get handled if it\'s going to be handled.
In the US in my area, I\'ve found Michael\'s to be the best place to buy dried flowers. I once found some mini gyp really cheap at Joann\'s, but i haven\'t seen small enough flowers there any time since. I\'ve gotten stuff at Hobby Lobby a few times too.
fieldarchy uses dried flowers often, you might look through her gallery for other examples.
I\'ve sort of \'built\' my own plants with dried flowers sometimes. The head of this \'rose\' is a large gyp blossom, the leaves are another type of dried flower glued on to the stem. Both have been painted. The flowering bush on this one is Woodland Scenics foliage with flower blossoms glued on. The bouquet is one type of flower for the flowers, another for the leaves, all wrapped around with sewing thread which was then coated with white glue.
The Necrotales site has some fantastic tutorials on base work - mushrooms, making leaves from paper, all kinds of cool stuff.
plus model do nice individual leaves. the oak and maple are especially nice. they only sell by the ton or something similar but other places stock them. they are well worth a look. as wren said, necrotales have some fab tuts too
Ask the artist. Fieldarchy is fairly active here when she\'s not working up a contest mini. Send her a U2U or an email. I bet she\'d be happy to tell you.
demonherald
The plus model leaves Tim mentioned are excellent ...
1:48 scale is best for 25-30mm models .. but there is no harm mixing a few 1:35 in there . After all nature is fairly random.
the best source for most leaf type stuff is the great outdoors.. just apply a little thinking kind of look at everything in the scale of the mini.
mosses , leaves , twigs , seed pods, dead heads on flowers , grass seeds anything is fair game .. generally either dry it out or seal with a little thinned paint varnish or other mediums is enough to seal it for mini usage..
same with aquarium and artificial plants ..rarely the full piece but just the odd bit here ad there.
If your struggling take a walk and take a mini in the scale you are using with you and just look at it next to these things to see what you could use them for.There\'s no substitute for experimenting ad just seeing what you can come up with.
plus model leaves
fieldarchy
The artist is in the house
Hey guys,
someone just notified me that there was a question as to the basing on my dryad I posted recently.
the rocks are made out of miliput and stuck to the base, some of the foliage is brass etching, the vines I made out of miliput, the butterflies are made with paper and then some dried flowers (the purple stuff) was from Michael\'s craft store.
Any more questions?
Oh and yeah, if y\'all ever have questions about anything I do just PM me. I\'m not on the forums hardly at all any more--that goes for just about any site.
But if I know someone has a question I\'ll give you the answer. I have no secrets.
Sauce Devil
Originally posted by fieldarchy
Hey guys,
Any more questions?
Hi Field, we were just talking about you :D
Thanks everyone, I\'ll probably resurrect this thread at a later date but for now I\'ll start with looking for dried flowers.
