GTTechnics
As I shift my painting procedure to doing more assembly prior to painting, I'm finding that I have more problems with stray paint getting into areas that they shouldn't be in. Normally it's not a big deal, but when I get a dab on a gradient created by airbrush or glazing, a small mistake turns into a headache. If I see the mistake as I do it, I normally load up the brush with water and flood it out, but once it dries things get a bit more complicated.
I've heard that some people lay down regular varnish coats and then use mineral spirits like an eraser, but I haven't been bold enough to try this technique yet. I've tried just glazing the mistake out, but when it's a dark spot on a light gradient this can take forever. The other option of course, is to paint a large section the base color and start over. How do you guys typically handle this kind of thing? Any tricks or tips? If you have a special technique for minimizing mistakes like this, I 'd be interested in that as well. I mount my models on cork for handling, but even then I find that I have to handle the model itself on finer details, and sometime this too can lead to a paint smudge if I'm not careful.
