72GMC said:
Could I ask your reasons? I've never had issues with milliput, I'd like to hear what others say about it.
On the plus side, Milliput cures good and hard and is nice to carve, sand or otherwise work dry. It performs well with water, for feathering out or blended to a slurry for filling surface imperfections and for sort of painting on detail. But the negatives... long list.
The unmixed putty can be hard at room temperature, hard enough that your fingers hurt when you're done blending. Very sticky once you get it mixing - not uncommon if you're mixing up a small amount to have more stuck to your fingers than in the ball of putty! So it can take a long time to mix as a result (and with Superfine White, they recommend you mix for at least five minutes) where MS or AS can be mixed in 30 seconds flat with
zero putty stuck to the fingertips*.
It has a relatively short shelf-life, being prone to developing 'Milliput leprosy' (the hard, cracked skin on one or both tubes).
It's expensive**, particularly at full retail (although you can find it for a lot less with a bit of searching).
And last but not least, many of the others are just better for what we use it for. Working characteristics aren't the only consideration but they're pretty high on the list and in a direct comparison of Milliput and any of the more waxy clay-type putties there is just no comparison for some people - stick to your fingers and tools less, easier to make do what you want, less prone to 'tearing' when dragging a tool over the surface, less prone to clumping when using water. Plus, the other putties are very forgiving of variations in resin/hardener proportion (either accidentally or deliberately, to vary characteristics).
If one doesn't have MagicSculp, Apoxie Sculpt, ProCreate or A+B you can simulate them to some degree with a blend of Milliput and Kneadatite to get an idea of what you'd get straight from the container.
*There is still a residue from mixing, which ideally should be washed off before proceeding. Alternatively, wear gloves or finger cots when blending.
**8.8c per g for Milliput versus 1.1c per g (!) for MS if you buy the 5lb pack at a good price.
