Hi guys (and gals),
I'm looking at starting out with some airbrushing, I've done some reading on it but that is no match for actual experience. Was hoping you experienced types could look at my proposed 'buying list' and point out any problems/things I've forgot/suggestions or alternatives you have.
A little info to help you out with this;
My Buying List
The following items would depend on what airbrush I decided to get to determine the exact model I believe, but I've listed them as things that I think I require, let me know If I'm wrong or missed anything;
Thanks in advance for looking and any input/suggestions/advice you have to this! xx
- I'm from England (this is apparently important information due to availability of parts/spares).
- I have a house-mate, and I'm not a heartless bastard, so a quiet compressor is a must.
- I've read that buying a 'starter' airbrush is a waste of time, and I like decent quality product anyway.
- It will be used almost exclusively to paint 28mm heroic scale (so around 32/33mm in reality) miniatures.
- I think I want a Side-Gravity feed (from my reading, this will give me a clear line of sight and allow me to hold the airbrush at different orientations and still have a feed).
- I also believe I want a 'Dual Action' (correct terminology?) airbrush - Where the air is started before the paint and you can regulate how much paint is fed into the air stream, as I understand it.
My Buying List
- Compressor - I know this is a 'DIY' type compressor and not a specialist airbrush one, but it is silent, available in my country and I've seen plenty of people say they use compressors that aren't specialised airbrushing ones with pressure regulators/hose converters just fine. Plus the specs for this look about right to me (although i have no airbrushing experience). Would there be any downsides to this? Any other suggestions?
- Airbrush - Probably leaning this way as the pistol grip looks easier to use IMO. But I'm open to suggestions, I hear Iwata, Badger and H&S (I think that's right) are all great makes, but I wouldn't know where to start with selecting a model.
- Hose converter - to go from the 1/4" compressor outlet to the airbrush hose diameter
- Moisture Filter
- Pressure Regulator - for the compressor line to make sure it doesn't go over the stated max for the airbrush by accident
- In-Line Air Control Valve
- Various Nozzle Converters - e.g. 0.2mm / 0.5mm etc for precision work
