Does Zahra need to have a movement point left to move into a hero's space
Kjelstad
So would she be able to move three, then move a fourth if there was a hero there?
Also, and I do not know the text so I don't expect this answered, but there was a card that my opponent had that forced me to reroll an attack. If I had used my rerolls on my first attack, would they still be available?
Also I assume a hero has to be activated to be exhausted, for example I can not use Chooloo to daze then activate a different character to attack.
Oh, and what about timing with characters like Serious Faceless. It says right after his attack he may move, this means before retaliation, correct?
VileMcNasty
1) Yes
2) Knight's Shield: "May exhaust your hero card to force an attack made against you to be rolled again."
Rabbits Foot: Exhaust your hero card to roll again from scratch either your attack or an attack made against you."
If they used Rabbits foot you would definitely get your rerolls. I still think that you would get your rerolls for the Knight Shield because it does not tell you
reroll your attack which would imply rolling from scratch.
3) A hero must be active to exhaust a card unless it is an effect of an ability being used against him (like Hate).
4) He moves as soon as his ability is triggered (rolls a hit), so yes before payback.
Kjelstad
1) I am assuming the yes is in reply to her being able to do it, not my topic. This is more of a comment on my badly worded topic/question than your answer. As long as she is still in her movement phase, it is a go. Well done on your part and thank you.
Arydis
Note that you can take her ability even further. With her ability, she would be able to use movement points between spaces without heroes to move multiple spaces.
For simplicity, say that in a line of five spaces, you have Zahra in space 1 and other heroes in spaces 2, 4, and 5 - She could move into space 2 for free, move into space three, move through spaces 4 and 5 for free and then use her remaining spaces to continue moving, using portals, or opening doors. She can mix the free movement with other movement.
Trigoras
Zahra makes good use out of the amulet of retribution since she can get guard reactions for free from monsters close to the spaces she's moving from. The rule that needs to be remembered is that a monster can only have a single guard reaction per hero activation. She'd be a strong hero to have in the final scenario. That room is super small and usually has a ton of single player spaces.
Trigoras
I don't believe such a rule exists.
my comment was in fact too general. It should have been from the same space. So a monster only gets a single guard reaction per activation per each unique space it is guarding.
Page 19 of the Rulebook as confirmation.
"It is possible to trigger several consecutive Guard Reaction
attacks from the same Monster or different ones in the same
turn, if each move the Hero executes leaves a different Space
guarded by the Monster. Keep in mind that using a portal or
manipulating a door does not trigger Guard Reaction."
