Normally I use spray primer, but with winter and colder temps that's not ideal, plus with both zombiecide Black Plague and kingdom death monsters sitting on my work bench I have ton of priming to do and painting over all.
I use wide range of spray on primers from GW modelmate army painter ect, so I know how each brand covers and which ones best suited for type of models.
But I never used airbrush primers; so which brands are ideal to use, color range and give off a good surface to work on.
i have seen Vallejo brands airbrush ready primers. And other recommendations or tips on using them.
Is is there different psi levels needed?
What about needle size?
Right now I am using a Iwata micron CM-C plus with .2mm needle and smart jet Compressor. Is the need to small for priming work? Normally I run paint thur at 14-20psi level.
