MrPickles said:
nothing to do with not understanding actually, i guess what i should have said is i'm not sold that microset does much of anything.
Using Micro Sol it may not really be necessary to use Micro Set because they double up a little bit on abilities. If you were enquiring prior to purchase I'd have suggested maybe trying just the Sol to begin with (especially if you were buying from a local source and not online) since this is the one that makes the starkest difference over any straight decal. But given all the experienced decal users who do use both I think there could be some genuine reasons to use them in concert, and you do have both already...
If you have any spare decals after this project it might be worth trying some experiments, see if you find that Micro Set makes any practical difference once all the over bases are covered - gloss undercoat, decal + Micro Sol, gloss overcoat, matt overcoat (+ weathering at whatever stage), versus the same with Micro Set before the decal goes down.
MrPickles said:
not this time. next time i will apply it on top of gloss varnish and see if there's a difference.
If you got any silvering then there'll be a big difference ^__^ but if you didn't get any silvering then it shouldn't make much odds.
Generally speaking it's considered a must to apply decals to gloss surfaces for good results as you probably know, but silvering is the main thing it avoids.
MrPickles said:
i assume this means it's going to screw it up and make it look funny.
I was referring to the "...brushing it on..." part, which would be risky to say the least - the Lacquer part of the name should be setting off warning bells.
