Decals and varnish??
zeromorph
I\'m going to be applying some decals to a few figures soon.
I think firstly I will spray the figs with a coat of gloss.
Then apply decals.
Then respray another coat of gloss.
Finishing then with dullcote.
Is this a good way to go about it?
Cheers
zero
Avelorn
Sven Jonsson
i\'ve never used decals for ages but.. are there any specific reason why you spray it with gloss warnish first? Otherwise it seems like a good idea. I remember I just added them and finished of with purity seal to blend them in. Or even painted over them to get the exact same finish.
Nomis
Got it in one
Then apply decals.
Cheers
zero
Th decals need a gloss finish to stick to if you put them on a matt surface they lift.
Remember to cut the decal as close as possible to minimise the possibility of the carrier film showing - I believe that the use of softeners is very effective but have never used them myself.
I also give the area a coat of gloss varnish before finishing with Dull coat - only you (and any one on CMON if you post the pics) will know they are decals and not hand done;)
zeromorph
Thanks Nomis.
Seems like I\'m on the right track.
And Avelorn \"Natali\" is absolutely stunning man. Very good work.
Cheers
zero!
