Dark green polished armour
oli457
Hi, does anyone have any pictures or tutorials on how to paint dark green armour so that it looks like its polished
thanks, oli
DaN
Dark green MARINE armour?
A la Dark angels?
Or fantasy sort of armour?
I take you want a technique rather than just using gloss varnish?
Look up the tutorials on NMM in the Articles section and substitute Green for the effect.
Make sure that you get a Flare of White in the right place as the ulitmate Highlight.
oli457
this is the effect i\'m looking to achieve. http://www.coolminiornot.com/153207
would the highliights be the same if i were to use dark green armour instead of black. ( marine armour)
DaN
Ahh, I suspected you meant something like that...
I have an (EVER ONGOING! lol) WIP along the same lines:
http://www.coolminiornot.com/forums/viewthread.php?tid=17510
I suggest first basecoating your figure and then dampening it with water, and taking a photo with a flash at the angle you want the light shining in order to see where the highlights and shadows are.
EDIT: Looking at my old WIP, the pics don\'t seem to be working, so I\'ll see if I have one to add now...
EDIT: Here you - This is as far as I got before I got side-tracked :p
Elly3438
Only thing I would suggest is to make sure alot of the original dark green is left... looking at brokenblades model, he builds up the shines, but leaves plenty of dark color to make it look shinier... and also like Dragonsreach suggests, a fine white or almost white highlight would surely finish it off~
DaN
Wappelious (Talented git that he is :p)
Has just submitted a chaplain using this technique.
http://www.coolminiornot.com/forums/post.php?action=reply&fid=2&tid=20787
skeeve
thanks, oli
Not sure whether it is what you want but you can look at mine here
http://www.40konline.com/mos/index.php?option=com_smf&Itemid=861&topic=134104.msg1624189#msg1624189
and here
http://www.40konline.com/mos/index.php?option=com_smf&Itemid=861&topic=128448.msg1555868#msg1555868
Wappellious
I think people have seen the color combos that were used for the black armor on the chaplain by now.
I will put a brief description of how I work here :
The key to my technique is to approach it as if the miniature was a watercolor, using very controlled glazes. Glazes don\'t have to be darker... they can also be used to lighten or highlight colors.
Certain brands and even colors of paint are more conducive to this, however, and the only way I was able to find out is through mass amounts of trial and error! :rolleyes:
My training was as a watercolor portrait artist, in case anyone was wondering about the obsession with watercolor techniques!lol
Here is one example also of why I paint in NMM/// there are no metallic paints in watercolors;)
http://www.jtwart.com/arthur/once_and_future_king.htm
demonherald
cool site..........love the stain glass art...
depending on the effect you want you could substitute the colours for greens or do it as on the black using grey shades and then glaze with green watered down paint ..several coats untill you get the effect....
@Dan sorry dude I removed them from my photobucket the other day having a spring clean forgot to check that the WIP was still active so the pics will be gone.
