creating Urban tarmac/concrete basing? (zombicide)
arkhanist
Coming back to fig painting after pretty much a decade away because of Zombicide - gotta get those zombies looking dead! Had more non-resurrectable paints than I'd hoped, but sorting that out with fresh supplies from Foundry, after seeing citadel have changed the mixes yet again.
Got my first dozen tabletop-standard walking dead finishing up now, but just realized I have no idea what to do with the bases.
I still have some gravel, sand and rubble; I used to do a fairly standard brown or grey painted sand/slate gravel mix with static grass (material glued on base prior to primer on standard figs, base and fig painted separately and pinned together for larger or better figs), and worked for fantasy and 40k.
But I've tried looking at one of my old figs on the zombicide 'modern' urban grey solid tarmac surface board, and it really doesn't match in style at all. I could do a light partial sand cover, but I dunno.
Floor tile sheets cut and fit to bases or shaped ' modern urban' kerb resin bases would probably work quite nicely, but that's a hell of a lot of work for 100 odd zombies (and want to play with painted minis asap) especially as I'll have to separate feet and base to boot (and either sand down or find new bases); but I don't want to just leave them as plain flat grey or black either (tried both, make me cringe a bit).
I'll be putting some proper effort into survivor bases though, probably will cheat a bit and base on urban resin.
Maybe colour match and paint street markings?
Any suggestions for this old warhorse trying to remember which way round to hold the brush gratefully received!
RuneBrush
I looked into tarmac effect briefly for the GD entry I'm working on (didn't go for it in the end).
Just searched for an image of the Zombicide board and I'd suggest gluing some medium wet & dry emery paper onto the base. You can always glue a length of plastic strip and make a curb too. Paint the whole thing grey with odd road markings and it should blend in quite well.
If you're looking to super realistic thin cork tile that you prepare the surface with a sand and then a really thin layer of super fine grit.
Shawn R. L.
Great idea of using sandpaper. At a good hardware store or a paint store (house paint or automotive paint) they should have sandpaper of different grits and different shades of grey - one less thing you'd need to paint.
the alleycat
Oddly i found that the best way of doing tarmac was using the old kind of flock [made of sawdust type stuff] that is mainly green. If you add it to a fairl moist layer of pva glue and then put it under pressure, it froms the kind of textured suface you see in freshly laid tarmac. Then paint black and drybrush as required. If you check out the warhound in my gallery, that's how i did the road :)
misterjustin
I texture dense plaster with a brass bristle brush. It takes a bit of time but you don't get a more realistic finish - especially when it comes time to do chipping and similar effects that you can't get with glue and/or sandpaper. Just use the brass brush to stipple the surface of the plaster. BAM!
Ordo Septenarius
This stuff will work great, and especially if you're looking to churn out volume:
http://pitoftheoni.blogspot.com/2009/05/black-lava-by-vallejo.html
nestorv
I am just going to echo what is already said here. Using sandpaper to represent tarmac is one way. This is actually a method used by military modelers to represent streets or airfields. Then with yellow or white paint you can represent the strips.
I am also thinking that using cork plates might give you the effect you are looking for. Just paint it in grayish tones.
