Dekulus
The best way to describe the effect I want to make is to imagine a space marine should shield/pad. I would like to make some extra raised sections that are vertical and horizontal like a cross. I was thinking of doing this (on flat sections) with 1mm plastic sheet or cardboard. Curves sections are more difficult and would probably have to use green stuff.
How do you get a piece of green stuff to be a perfect long strip the same thickness all the way along. My guess is you have to use a blade and somehow cut it perfectly. Any ideas ?
Thanks in advance.
Thanks in advance.
