commenting on articles?
Jana Wang
I\'ve got something to add to the article on using the spice rack as basing materials, how the heck to I add a comment? I\'ve been over it three times and I can\'t find any \"comment\" buttons or links or even broken javascript like on the rest of this site.
How?
Garyo
Scroll to the bottom of the article page. Find the box, type in your comment and click submit... :)
Garyo
Chern Ann
Only when they're green
Just a correction, the site has no broken javascript (ie we are fully 1.0 compliant); Mozilla 1.0 has a non-standard javascript implementation; I\'m not sure about Opera.
It sounds like you aren\'t logged in, which is why you can\'t see the comment box. Use this page to login first: http://www.coolminiornot.com/login.php
The site does not work if you do not accept cookies.
shortboy
Chern is correct on the not logged in comment. I tried to post comments for three days thinking I would get a logon prompt when I tried to post the comment. I tried logging in before I tried to post and it worked fine.
Lurch
Try changing the background for when you are logged in to something other than the default blue. that way, if you are logged out, you will notice it becuse the site looks different :idea:
Jana Wang
All righty, logging back in did the trick. Of course, the screen *said* I was logged in the first time....
As for the broken scripts, the \"comment\", \"login\" and \"news\" links on the main page produce \"javascript: VOID (0)\" errors when I try to use them, in Netscape, MS Explorer, and Mozilla, on my machine, and the other two machines I have access to. Something somewhere is not working and I\'ve tried various alternatives from my end with the same results.
Chern Ann
That\'s not an error, you\'re meant to left click on the links which will pop up a new window so that you can login. Of course, if you\'re running software that completely disables pop-ups, that won\'t work.
