I am on a painting spree and have done nothing but paint my Tau army over the last few days. As such, my basecoat brush has taken a beating and even my WN S7 brushes are starting to splay a bit. I thought of buying one of those paintbrush cleaner wax/soap, but then I remembered I have some Fairy Power Spray that I have been using to strip a few models. I tried FPS on my brushes and it did take out a good deal of gunk. However, I wonder if this is good for my brushes? Can I soak my brushes in FPS overnight or for a certain period of time or should I just wash-and-rinse?
Also, I have noticed that my drones have a certain "texture" to them... they're not smooth like my other minis. I wonder if this is because I made a mistake when priming them? I usually prime by putting the minis on a plank of wood, then spraying the primer on the minis, turning and moving the minis/primer to get the primer in all places. However, as I was priming a lot of small bits (drone, drone guns, etc.), I decided to put them in the Tau battleforce box and spray the primer into the box. It was quite windy so maybe I overkilled a bit on the primer? I'm getting tempted to strip my drones and guns now.
