Hi DoBe, how to paint the pupils? They\'re always a bit of a \'mare for me which is why I paint the eyes as the first thing on the head (\'eavy Metal always seem to do them last). There are various face/eye painting tutorials you can reference but here\'s my most recent process...
You have his iris\'s nicely centred & he doesn\'t look cross-eyed, well done, next is the black pupil dot. First work out what angle you\'ll hold the brush at. Hold the figure up so that you are looking directly into his eyes, that line between your eye & his is the line you want the brush to follow. Do this & both pupils should be looking in the same direction. I\'ve found that I used to hold the figure upside down to paint one eye because it was comfortable, then hold the mini sideways for the second eye, hold it up & the pupils, even if within the iris, often looked a bit squiffy! The other reason for knowing how you\'re going to hold the figure/brush is because there will be so little paint on the brush that it\'s going to dry quickly, you need to go straight from pallette to execution without fannying about at all!
Chaos black on the pallette, small amount of water alongside for gradual mixing, brush with the finest point (not necesarily your smallest one!), paper kitchen towel sheet. Paint on brush, fine dot onto paper - does it spread? too wet. Is it a dry little scratch rather than a round dot? too dry. Keep going until you can see from how much paint is on the brush that you\'re going to get a neat dot, breath out, dot in pupil. Easy eh? lol I\'ve found that if I can see a bead of paint on the end of the brush then it\'s too much, trail brush across pallette for a cm or so leaving a spider leg thin line, just enough paint left for a neat dot.
Next you can dot in the even smaller white reflection marks if your\'re feeling confident! (I\'ve achieved this a grand total of once! on my gallery Snotling).
I don\'t think your photo\'s too bad at all, if you want to feel better about it, cruise the galleries for some low scoring models
Just crop out some of the background & let me see his back, you\'ve done a nice job, now share!
Rainbow Company should be fun. As long as the bases & metals match they should theme together. You could strengthen it slightly by choosing one common colour, leather all the same, or all blue bags, just to keep them thematically unified. When they\'re ranked up will they follow the colour order of a rainbow? So that a 7 wide, 50 deep unit would stretch back across the table like a rainbow? (Red on the left through violet on the right).
Just some thoughts, looking forward to seeing the rest, :beer: B.
