Citadel to Vallejo Conversion project - Need help.
Coyote
Someone put out this link before, somewhere on the web.
Basically, I\'m looking for a company that sells 17ml capacity squeeze bottles. Essentially, the bottles that vallejo uses.
Then I can move all my Citadel paints over and not have them dry out as much.
Chrispy
Yeah Great Idea, I\'ll need it too.. It would also be nice to find a way to take off the squeeze cap, I have had some blockage when I don\'t skhake them well..
Coyote
Uhm, hook your fingernail between bottle and tip, and carefully (to reduce splatter) pry upwards.
It can be done, they are not glued on.
This allows you to do 2 things:
Manually stir the paint when you first get it
Add stainless steel ball bearings (if you can find them)
Aschul
I think it\'s better to remove the tops with a pair of pliers. Get a good hold on it, then slooowly twist and pull it carefully off. A bit of splatter is inevitable, but if you\'re careful it can mostly be avoided. I also keep a pin handy on the painting table; if the bottle gets clogged just insert it in the tip to clear it up.
