Broodlord assembly problems
Gapow
I\'m having a real problem assembling my Broodlord. Do they arms need pinning, if so how\'d you go about doing it, as the model has weird shaped half sunk triangular holes in the body.
Also are those square things supposed to be on the elbows, I can\'t decide whether they are just flash or not, tah
the Infadel
that was one of the toughest models to put together. yes, pinning is required if you want it to stay together, with a good dose of green stuff. good luck.
Gapow
Will Milliput be ok instead of Green stuff? I\'m gunna have to use that on his legs anyway, as I need him to be able to fit onto a 25mm base, so will have to bring the legs together creating a gap at the top, think it\'s going to be a nightmare
