Benihana
It's high time I posted, and perhaps that will help me get things moving. A bit about myself: I'm 28 and living in central California. I was in the Navy on the East coast for 6 years, got out and wasted a year or so on World of Warcraft, and have since been working toward a Mechanical Engineering degree. I originally had the idea that making WoW minis would be fun, perhaps with sets of weapons and armor that the customer would select depending on their character, but have long since abandoned the idea. My first mini purchase was a dwarven command set for reference, which I still have around here somewhere (last edition I believe). I have a few projects on my plate, the largest, my Skaven army which I have been slowly collecting, which is in various forms of bare plastic to painted metal (but will all be stripped), and is mostly only missing some Stormvermin, Jezzails, and custom units I'm planning.
I chose this next mini because I loved the sculpt for some reason, with the exception of the face. Her head is too large, her eyes are too high, and her face is too round. I'm going to attempt to correct that (I've already shaved the metal a bit) but I'm not totally certain how to proceed. I'm worried I may have to lop it off and craft her a new one. I've decided to paint her in Protectorate of Menoth style, because I like the colors, and if I played WM in the future I could perhaps use her somehow? The base is constructed from gears from a toy robot (which had a disappointingly low number of gears - I've tried to find broken watches but thrift stores seem to want way too much for them). The small gear has a pin going through which lines up with the base in the back, as does the screw gear on the left. The Menoth symbol isn't as rough in person, but I'll still probably try to clean it up a bit. She will sit a few mm lower once I drill the gear she's standing on, and cut her slotta to fit, or pin her in.
IMG_0002 by benihana, on Flickr
IMG_0007 by benihana, on Flickr
Here are some ideas for the paint scheme and freehand detail. The shoulder trim, elbow and wristpad, and perhaps boots will be gold with dark relief. The shoulderpads, perhaps arms will be Menoth red. The cloak is white (with perhaps gold trim), and the chainmail and mace (once straightened) will be dull silver metal. The nameplate looking things on the shoulderpads are a bit odd to me, I wasn't sure what to do with them.
IMG_0018 by benihana, on Flickr
This is another figure I couldn't resist after the first time I saw it. I'm not planning to do much, if any, conversion work on the figure, except fix her miscast scabard (I've already shaved it down). The old style radio/phonograph is meant to have a sort of steampunk-ish feel (without being overly steampunk), to fit with her guitar. It ended up a bit larger than intended, and seems to dwarf her, so I might redo it (and give the speaker part more curvature). I tried having it come out of the top, but it looks better curved around the back (currently stuck on with clay). The amp part will sit on claw style supports, and I may add a few cables going to her guitar. She'll also sit flush with the base –I may add some kind of stage.
IMG_0012 by benihana, on Flickr
Next up is Skaven. For now I'm only giving a teaser. These are not going to be used as shields or bases... but they are about the same size as a large shield. I don't like how the third one turned out, so I may redo or come up with something different. The first one needs trim, and the second will look better when painted.
IMG_0016 by benihana, on Flickr
These are custom shields which are much larger than the current Skaven clanrat shields (about 3 or 4 would fit on one of mine). They are meant to be tower shields, though I plan to make some other more rectangular tower shields. The "S" shield is the first of 6... (think "parade" if that's not enough of a hint).
IMG_0017 by benihana, on Flickr
For fun I'm including photos of my first crafted mini. It was made with super sculpey and was before I owned many tools (or rather, before I owned clay shapers, since that's most of what I use now). It is an unfinished Tier 5 priest from WoW ( http://static.wowhead.com/uploads/screenshots/normal/63659.jpg ), and stands about 25mm. When I photographed it, I forgot the staff's top section and bottom are connect by energy thingy, and my original intent was to have the bottom part secured to the base, and the top held by the priest (but aligned with the bottom, a few mm above). If I decided to finish this project, I would certainly redo it using green stuff, magicsculpt, and current tools (super sculpey is just too rough and granular).
IMG_0020 by benihana, on Flickr
IMG_0026 by benihana, on Flickr
And finally, from the same era, a stormtrooper helmet that was meant for a Star Wars project which involved making Micro Machine scale (true 20mm I think?) figurines, but better and with more poses. It didn't photograph well, there's a bit more detail and it's not as rough. Still, I'm including it for fun, I probably won't finish, and if I do I will most likely redo everything. I would definitely like to have ranks of hundreds of stormtroopers one of these days though...
IMG_0022 by benihana, on Flickr
Comments and criticism [bold]very[/bold] welcome (except the last two, you're welcome to comment but I'll just smile and nod if you critique). I'll do my best to keep posting and keep this WIP interesting.
I do have a few questions for you all. I replaced my unmentionable-crap-quality-retail-store-soldering iron with what I'm pretty sure is a decent one from Micro Mark. I'm trying to weld some armatures together, but it doesn't seem to be working. I understand I'm supposed to heat the metal so that it melts the solder (instead of melting the solder directly and trying to add it to the metal), but the metal doesn't get hot enough. When I do get the solder to stay, the joint is very weak. Am I perhaps using the wrong kind of metal, solder, or soldering iron? Should I just switch to brown stuff or the like? I thought the solder would be strong and give a realistic weld look where left exposed.
Any suggestions on a Skaven abomination? I probably won't field it, but I'd like to build one. I absolutely hate the official model, and I'm not a fan of most of the customs people have done (Jabba or Jabba-on-wheels). So far, my best ideas are a giant rat ogre with steam tank plates for shin-guards, and perhaps a giant (custom) censer, or a giant naked mole (Warpstone mutated of course), or perhaps hijacking Leon Brachwurster's Mechanical Menagerie, because it looks both awesome and plenty Skaven-y (I'd modify the wings a bit of course, perhaps make them tattered leather or something to explain why it can't fly).
Eventually I plan to get either a set of Warriors of Chaos, or a hero that uses those shields, because I like the look. I'm also planning to do a unit of Quar from Zombiesmith, and I'm always on the lookout for interesting models and more ratsssssssss >
