Article: HITECHMINIATURES NEWS
groom
Trained to read ? There is information that model consist 10 pieces (hips and torso separately) that is mean You can make this with many different poses ...your competitor ? :) Not perfect but garbage ? Must be something in the water :)
blackfly
One would hope that they would make the pieces into the best example. By that logic, if this is the best you can make with the 10 pieces, then all the other options will be garbage too.
