Some questions came up about how this item is used because of the somewhat vague description it has.
1. Does this item activate regardless of which guild member you activate. It just says, at the beginning of your activation.
2. Can this item hit all close enemies to the guild member equipped with it. I believe the description is, "You can place 1 wound on any close enemies"
For this purposes of the game with played, we assumed that I had to activate the guild member equipped with the crown to activate its ability. The way the card read though, made it seem as if both points were true. Was curious if anyone had any thoughts.
