So my photos left a little to be desired, to put it nicely. Using lamps and paper or card stock, I was getting results like this:
Those aren't cropped or touched up, and passable. I read the Ikea trashcan lightbox idea, and looked around for something suitable. What I did find was the VARMLUFT Shade
Now that doesn't look like anything you can use to photograph minis, but inside is a wire frame cube covered in paper. Just cut away the extraneous material. Cost? $5
I also ran across These JANSJO LED lamps for $10.
I bought 2. They're super flexible and let you put the light where you want. They are spots, so you can adjust how much light the mini is getting as well.
Here's what the setup looks like, with one lamp.
The light it makes on the inside:
And the flexibility (pun intended) of the setup.
Now compare those photos above with these:
All from $15 at Ikea.
