Ok first pic. Boring one but showing that this one isn’t going to fall apart. Heavy brass welding rod used to pin parts along with epoxy resin and superglue.
View attachment 26616View attachment 26617View attachment 26618
Then comes the start of the painting. Undercoated then purity sealed.
Pre shading done
View attachment 26620View attachment 26621View attachment 26622View attachment 26623
First colour base, wash and then second preshading done on body and wings
View attachment 26624View attachment 26625View attachment 26626View attachment 26627View attachment 26628
2nd highlight, + 3rd and 4th colour balances for sub skin texture.
View attachment 26629View attachment 26630View attachment 26631
Armour 1st, 2nd and third colour layers for deep reds on main panels.
View attachment 26632View attachment 26633View attachment 26634View attachment 26635
The wings get 2nd 3rd and 4th colour layers on supporting fingers.
View attachment 26636View attachment 26637
Sub surface skin done and top skin done
View attachment 26638View attachment 26639View attachment 26640
Armour panels done. Metallic parts started
axe blade flesh done
View attachment 26642View attachment 26643
Wing fingers completed. Membranes get final pre shade
Metallics on armour panels done
View attachment 26645View attachment 26646
After final assembly the big guy is done
View attachment 26647View attachment 26648View attachment 26649View attachment 26650View attachment 26651View attachment 26652View attachment 26653
and for size comparison
View attachment 26654View attachment 26655
This was a beast to do. It’s pinned with brass tubing, brass welding rod, even more brass pins then glued using epoxy and thick set cyanoacrylate. The model is pinned to the base with more brass and epoxy then sealed to the base with hot glue.
Was a lot more work than I expected but was a joy to do.
any feedback is welcomed
