Aternox
Hello everyone. This is my first post here on CoolMini or Not.. I started out as a very traditional artist.. large scale painting, drawing, charcoal, etc.
Over the past several years I have gained such a strong appreciation for all you miniature painters out there. Unfortunately my miniature painting skills have not come to the same level as my traditional painting skills.
Anyway, I was wondering if any of you experts would mind giving a many-year novice some advice. I have a W40k Necron army and for some reason (after about 40 attempts) I\'m not getting the effect that I\'m looking for. If you don\'t mind, I\'ll walk you through some of the problems I\'m having. My hope is that many of you will have simple solutions.
I\'m not exactly sure why I care so much.. Ok.. ok... The truth is that I want a paint job that is going to make my friends ooooo and awwww.
I\'m going for a dark ancient alien metal look. Here is my current attempt with some of the unwanted results.
1) Primed in Chaos Black
2) Painted on Boltgun Metal on body and a darker (almost black) version on gun.
3) Washed in a mix of Badab Black & Dyvlan Mudd.
(Though this looked good wet, after drying it had lost some of its drama.)
4) Second wash in the Badab/Mudd mixture.
(This restored some of the drama but from a distance it really didn\'t do much but darken the overall miniature.)
5) Highlights in Chainmail using drybrush.
6) Localized wash of Scorpion Green in the rib recesses of the chest, the joints of the vertebrae, eyes, mouth, and gun vents.
(This was supposed to give it a really good glow from within. Unfortunately the wash was difficult to control and corrupted the surface wash of Badab/Mudd. In addition, when it dried it tended to stick to the sides of the recesses rather than in the center of them. Would I be better off painting this into the recesses instead of using a wash? ...or would it be better to do this in a different order with more coats?)
7) Mixed a little Pearl Ex Gold Interference paint with some gel base that the art store recommended and thinned it out with water. Painted this over all the raised areas of the model to give it an alien glow.
(I tried many things here. Unfortunately the \"clear\" base that the paint store recommended tended to dry a little on the white side after mixing with the Pearl Ex. I also tried Golden Green Interference paint but it turned out a little too... hunter green that what I was looking for. I haven\'t tried the Golden Gold Interference yet but I have it.)
In the end it really didn\'t have the pizzaz that I was looking for.. I found a few sites where I saw people using color shifting paints (green-purple) but I\'d rather not get too overzealous with special paints.
Can anyone lend some advice?
Thank you in advance.
