Airbrush compressor and other accessories recommendation
Gearjock
So I think I am decided on getting a Paasche TG-3F for my painting needs. However I'm still at a loss for what I should get for a compressor. I don't mind spending between $100-$250 so long as it gets the job done well and isn't going to make me go deaf. Also, any recommendations on other accessories I should get (besides a mask, which I know to get
) are also welcome.
Spacemunkie
I've got a Talon and it's a decent gun. Only minor gripe is the trigger action which is a bit crunchy, but gets better with use or a bit of careful polishing. It's very versatile thanks to the various nozzles/needles that can be fitted.
I'd recommend a tanked, oil-less compressor. Moisture trap/regulator. You may need to buy some hose adapters. I've used something similar to this for years with no problems:
http://www.trademe.co.nz/art/art-supplies-equipment/other/auction-491484849.htm
I've even got the piddly little tankless version and that works ok too. Just gets a bit spitty with prolonged use.
QuietiManes
The little quiet airbrush and hobby compressors are expensive and under powered. If you look at the top of your price range, you can get a compressor that'll last forever and you'll be able to do anything you want with it. Air tools, spray guns, airbrushing t-shirts, etc, none of which can be done with most hobby compressors that have a max of 30 PSI (20 running).
For example:
http://www.gmcgenerators.com/?page_id=46 <= it's actually compressors, not generators.
Of course, if all you're going to do is occasionally prime and/or base coat a couple models, a $50-$100 hobby jobby will do you very well.
Gearjock
The device will not be used for anything else but for painting my minis. I plan on using it for full on painting as well as for general basecoating and primer.
Home Depot, Lowes, Sears, etc. are your friends here.
Full on painting includes t-shirts? You'll need more air at higher pressures than the little 1/10 & 1/8 HP diaphragms can do.
Get a moisture trap and a regulator. Lots of smaller airbrush compressors have them combined.
I'd personally look for something along the lines of a 1/2 HP pancake model, but both of my right now are hot dog tanks.
Noisy is relative. What is not so bad this afternoon may not be pleasent to the wife at 2:00 a.m.
Get them to plug it in at the store or pay attention to the dB rating.
Feel free to post questions as you go.
