Almost all of the paint on the figures in
my gallery is various types of artists\' acrylics :flip:
If you buy good brands the pigment particles will not be noticeably coarser than in hobby paints (sometimes the reverse!) but some of the above is right on the money. As a rule hobby \'acrylics\' are actually vinyl paints and vinyl tends to have noticeably better adhesion than true acrylic, although over a good primer this is much less of an issue if you intend to handle your figures to any degree then bear it in mind.
In general you\'ll find that coverage is not as good as you\'re used to because paints will be manufactured to show off the natural character of the individual pigments - some of which are
very transparent - unlike paint like Vallejo Model Colour which may have added opacifiers to help even up the coverage across the range.
You\'ll also find that artists\' acrylics in tubes are usually a fairly heavy consistency - nearly that of toothpaste in some cases - so you\'d have to get used to reducing the viscosity of your paints somehow and using an old brush for this and for mixing just wouldn\'t be practical, as it can be with a fluid paint.
Coupled with all this there tends to be a small variation in surface finish, even for a range made to dry fairly uniformly, and the normal finish for tube acrylics is satin or semi-gloss anyway. So you will have to use a matt overcoat of some kind at some stage. On the other hand these sorts of natural variations can be useful if you\'re seeking to replicate a range of sheens - matt for cloth, a slight sheen on skin and a semi-gloss on leather and so on - although you can do all of this manually after you\'ve sprayed a mini with Dullcoat if you wanted to. Since many minis are intended to have a uniform matt finish it\'s probably a better idea to stick to a paint that naturally dries that way.
Despite all this if you did want to try something different to Vallejo, Andrea, Citadel or one of the other mini paints consider
Jo Sonja\'s Artists\' Colours, they\'ll sure work out cheaper I can guarantee that! The Wolfen in my gallery is mostly painted in these and almost all of the fantasy minis I\'ll be submitting in future will be too.
